  • 136 Vote(s) - 2.99 Average
Does anyone know what will replace this?!
Hi! Have just moved to a new property with an electric gate - the gate key doesn't work and I'm trying to figure out how/what I can replace it with! Any help gratefully accepted Smile
Do you know what frequency the remote is working on? If it is working on the 433Mhz frequency you could use one of our cloning remote CL4000. I will post a link to our website showing you these.
http://www.easygates.co.uk/universal_remote_control.asp
Kind regards
Tim
did you check battery ?
are you sure the gate are powered up ?
regards
Best Regards
Tom
Hi! Thanks for your response.
I'm not sure what the frequency is - is there a way to find out? Also I don't have a working gate key - is it possible to use a cloning key if you don't have any that currently work?
Yes have changed the battery and that hasn't helped. And the gates must work since the bin men get in to empty the bins!
(28-05-2017, 09:36 PM)cjones Wrote: Hi! Thanks for your response.
hi . spend 15-25 pounds for new receiver and transmitter thats my advice for your problem .
to check frequency you should have frequency scanner
Best Regards
Tom
  Replace Remote Control H-055 agafed 2 11,605 02-11-2023, 02:51 PM
  repair or replace blueberryhill 1 5,113 05-02-2021, 11:02 AM
Cool Does anyone know this fob or what could replace with dawn 2 15,296 24-01-2015, 09:12 AM
Last Post: dawn
