  • 198 Vote(s) - 2.91 Average
BFT Gate Below Ground Hydraulic swing gates no pressure in one
I am in NZ and finding it difficult to get someone to service my gates.
I have very heavy wooden and metal gates with 2007 Installed hydraulic motors in the ground. One of the gates no longer has any tension in it, it swings quite freely in the wind. On opening and closing it doesn't quite make it to the stop position, maybe because it runs out of time as it is going slowly. Can anyone give me any guidance as to troubleshooting, what may be the problem/solution?
To access the motors the gates would need to be taken off, which would be quite a mission based on their weight.
I have tried the winding key supplied, turned the little 3 sided screw completely to the left and the right, it made no difference to the tension in the gate. I am not 100% sure what that key is for so at any rate!
I tried the company website, but couldn't find any trouble shooting manuals and their education area was blank.
Thank you.
From the information provided it sounds to me as if it could be lack of oil in the motors. If there's no pressure, then this may be the main cause.
  Gate wont close issue MR_ROBOT 3 9,702 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,271 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 946 14-02-2024, 12:18 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,155 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,172 02-10-2023, 09:08 AM
  Set remote to “only open” gate mark123499 4 3,832 30-05-2023, 01:57 PM
Last Post: mark123499
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 3,200 23-05-2023, 03:48 AM
Last Post: Bushpig
  Gates not fully closing stefen1978@hotmail.co.uk 2 2,752 10-10-2022, 10:07 AM
  Parallel (or not) gate motors Ian Evans 1 2,472 16-05-2022, 11:44 AM
  Best BFT for closed aluminium gates rafp 1 3,007 13-04-2022, 11:38 AM
