  • 228 Vote(s) - 2.86 Average
Genius 452/455 Learning Issue
#11
Hi there
Just to let you know the gate is now programmed and working perfectly.
Thank you for all you help.
The reason for it not closing was a broken IR beam sensor.
Cheers again
(03-01-2017, 07:14 PM)Automatic-TC Wrote:
(03-01-2017, 10:27 AM)Robedj Wrote: Im assuming that I can simply disconnect these safety devices, program the gate and then re connect again?
you dont have to disconnected any devices .
I have a similar problem with a Brain 16 control board , it seems to have lost its ability to accept the learning times ,
question: is there any simple learning procedure with Brain 16 just like JA574 used to have
  Genius JA592 issue fintaneduffy 3 698 19-01-2024, 09:58 AM
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,540 25-05-2023, 03:55 PM
Last Post: Kaala1
  BFT IGEA BT issue warren5 1 2,845 13-04-2022, 11:49 AM
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 5,238 02-05-2021, 09:00 PM
Last Post: soother
  Beninca BOB21m Photo cell issue Rossm1987 1 4,249 02-05-2021, 12:39 PM
Last Post: Rossm1987
  BFT C130 Photocell Issue labbetts 0 3,931 25-01-2020, 05:01 PM
Last Post: labbetts
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 4,477 28-11-2019, 12:11 AM
  Genius Gate System Problem grasshopper 1 10,887 01-07-2019, 09:39 AM
  Genius JA574 problem jeeter 0 4,629 02-05-2019, 01:13 PM
Last Post: jeeter
  Strange gate opening issue (NICE) FrNiscars 3 23,136 09-11-2018, 09:48 AM
