  • 234 Vote(s) - 2.98 Average
Remotes not working
Exclamation
Hello all knowledgeable peeps.
So we have a liftmaster gate opener, supplied by Easy gates over 10 years ago. it opens two gates and works manually from the button OK. but all 3 of the remotes have now stopped working.
I have been through and pressed the CH1 button for each of the remotes and waited 30 seconds until the light goes out.
they all have new batteries and now when pressed you can see that they are communicating with he board as the CH1 and CH2 lights are flickering. but no click or gate opening happens.
Trying not be a dumb blonde, but could do with some guidance, as its now getting cold and wet and having to manually click the button is a pain in the proverbial!!
Hi Jo,
If all remotes had stopped working at the same time, this would indicate a failure of the receiver. Do you know which system you purchased from us?
  Control Unit Not Working mtuk100 0 39,132 10-10-2019, 03:14 PM
Last Post: mtuk100
  CB11 control box Intercom release button not working Moreteyne 0 8,964 14-09-2011, 03:14 PM
Last Post: Moreteyne
