  • 190 Vote(s) - 2.95 Average
FAAC 740 - help needed!
My FAAC 740 was working fine yesterday, but today it stop working.
If I put it on manual mode, open the gate and then put it on automatic mode then it closes the gate. But that is the only action that it performs. After it is closed it doesn't do anything.
I checked the display to see the status and it stays in 02 status when it is closed.
Does anyone had a similar issue?
thanks in advance
Norberto
No Comments? can anyone help me?
dos it close normaly with slow montion in the end or just hit hard against post ?
regards
It closes normally.
Regards,
Norberto
(11-12-2016, 10:45 AM)Automatic-TC Wrote: hi
regards
ok ,status 2 mean that the gate was stop by some external signal (remote,button,loop)
if you got instaled some paralel signal wires you should disconect them for short time and live motor operated only from remote control
I already had it removed from the equation. there isn't any cells configured and the motor is running in without any other signal. The only signal that it receives is the remote, but that is only when I press the command.
Sad
Any other suggestion?
Regards,
Norberto
(12-12-2016, 08:14 AM)Automatic-TC Wrote: hi
if you dont have any of external operating signal and any of security devices you should1) chek two stop sensors which is install above external gear.2)output engine wires in socket could tarnished 3)after pressing remote button you shoud heard some noice from relay on mainboard
4)take of receiver out check pins ,slid in again ,you can delete all transmiter and setup them again
  Faac 452 pcb board benner91 2 1,704 09-02-2024, 06:13 PM
  Faac photocell stopped working Zeb Gulickx 2 954 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  FAAC E124 fault 05 allan@amtas.com.au 0 711 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 3,927 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 1,202 23-06-2023, 03:19 PM
Last Post: Alpin
  FAAC Photocells mmc1977 3 2,305 02-05-2023, 12:37 PM
  water damage to FAAC photocell Rajab 4 3,562 18-07-2022, 09:00 AM
  455d FAAC FUSE IN CONTROL PANEL wildfig 0 2,079 04-10-2021, 02:34 PM
Last Post: wildfig
  FAAC foundation plate mun31 1 4,989 30-06-2021, 09:33 AM
  Faac 740 Mozil 3 16,261 13-06-2021, 07:51 AM
Last Post: david@venusawards.co.uk
