  • 230 Vote(s) - 3 Average
BFT Rigel 5 with a Z-Wave Relay?
Hi guys,
I'm looking to wire up a wireless relay into my old Rigel 5 box that controls our gates.
I've had a scan through the manual and roughly figured out where I should be heading but i'm still a little confused.
I want to use something like, or similar to these
https://www.amazon.co.uk/Z-Wave-2%C2%A0S...baro+relay
http://www.vesternet.com/z-wave-fibaro-r...t-1-2-5-kw
They power off mains, so I was thinking I could use 10-11 on the board for Live and Neutral.
Then how would I send the "start impulse" I imagine I would wire NO1 from the relay in the first image to perhaps 32? "OPEN", or would it be 28?
There is another product from Fibaro called the Roller Shutter 2 which rather than just trigger the "start impulse" could technically open and close the gates, presumably that would go into 32 for open and 33 for close? Whilst that would give me more control, id then have to program my home automation system (SmartThings in this case) to also close the gates behind us, it makes more sense to let the Rigel 5 do this as its been doing successfully for years - and program SmartThings to "press" the start impulse again if we want it to keep the gates open at any point.
Looking forward to input from those that know the Rigel panel - we did have a push button door bell wired up to this at some point, so i'm assuming its actually fairly easy to send start the "start impulse" command.
I've been told on the SmartThings forum the Mimolite is the thing to use for this.
It has a COM and N.O. output, so to trigger the start impule I assume I want the COM to go to 27 and the N.O. to 28?
Hopefully someone could confirm that.
Anyone?
Dan
I see on the SmartThings forum that you got the MimoLite working with the Rigel 5. Can you confirm the connections, as you mention 2 different ones in your various posts?
thanks
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 868 04-01-2024, 10:21 AM
  smart relay BFT ALTAIR halt23 1 586 13-11-2023, 11:45 AM
  smart relay BFT ALTAIR halt23 1 421 13-11-2023, 11:45 AM
  Rigel 6 conections Muttlymoo1979 0 1,021 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,310 05-01-2023, 11:53 AM
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 4,426 10-10-2022, 01:10 PM
  Rigel 6 - doors do not stay open Poweroftaxi 1 8,931 13-04-2021, 02:41 PM
  But Rigel 5 and Deane a15 cells Matt Hey 2 8,538 30-03-2021, 07:57 AM
Last Post: Matt Hey
  Bft rigel 6 PHCL tidoh2021 1 11,654 12-03-2021, 07:31 PM
Last Post: russ
Smile Rigel 5 Manual override Stramorebees 0 10,069 20-09-2020, 12:03 PM
Last Post: Stramorebees
