  • 194 Vote(s) - 2.99 Average
BFT Deimos QSC D LED display stuck on 'cLS'
I've been trying to program additional mitto remotes and the up/down/ok switches on the QSC board are not doing anything. The LED display is stuck on 'cLS' and only changes to when the gate is opening and closing.
Otherwise the gate still opens and closes fine, together with the flashing strobe working.
Is it possible that incorrect wiring on terminals 21 to 26 could have caused this? I replaced a worn motor a few years ago and whilst I'm reasonably certain I put everything back correctly I may have made an error.
Also this unit drives external lighting on/off via terminals 12/13 I believe.
Would be grateful for any pointers.
Best regards,
Turned out on the unit I've inherited there is a suspected)erroneous photobeam input attached to terminal 21. Taking this away provides access to the menus now.
  Came ZA3 gates stuck open Ivorwindybottom 0 326 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Came gates stuck open. Ring8180 7 16,877 23-02-2023, 01:08 PM
  Nice gate stuck on open akkers 5 11,992 28-06-2021, 09:43 AM
  Deimos BT 400/600 error codes orange 0 3,892 07-12-2020, 09:36 AM
Last Post: orange
  Faac 455d Gates not closing, 2 led bars on display only Mkeowd 0 4,384 26-09-2020, 02:29 PM
Last Post: Mkeowd
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 4,462 28-11-2019, 12:11 AM
Last Post: dawoodejaz@hotmail.com
  BFT Deimos BT Error Codes rajesh 1 17,022 05-06-2017, 11:07 AM
  BFT Deimos QSC D second function relay for external lights roadrunner 0 5,459 08-08-2016, 05:42 PM
Last Post: roadrunner
  BFT Deimos QSC D not accepting new mitto remotes roadrunner 3 14,445 08-08-2016, 05:37 PM
