  • 217 Vote(s) - 3 Average
Gibidi gate opener. Add a wired switch.
    Guys wonder if someone can help like to put in a wired switch
to operate gates, it is an old unit installed late 1990's looked
on net no luck on a wiring diagram . I assume it is just a 2 wire hook up cheers. Gibidi plus 2a?
(23-01-2016, 07:17 AM)Eagle_man Wrote: Guys wonder if someone can help like to put in a wired switch
Hope you are well. If you wish to use a push button to operate this you will need to wire into 16 and 18. This is the N/O input, please see the manual below showing this.
https://files.uk2sitebuilder.com/94/09/9...76c4e7.pdf
(page 8/16 PDF).
Kind regards
-Jamie
  Beninca sliding gate. Rogeramjet 1 4,290 22-11-2021, 06:14 PM
Last Post: Asaded
  Hello Looking for gate control help everettc4 1 6,504 05-02-2021, 01:12 PM
  GIBIDI gate motor closing problem davidcunningham 0 7,956 26-04-2019, 07:46 PM
Last Post: davidcunningham
  Inherited GiBiDi Gate Shuggy73 2 12,722 13-04-2018, 05:18 PM
Last Post: Shuggy73
Cool Hello :) Gate/Barrier Engineer MrDiagnostics 0 7,783 29-04-2017, 09:48 AM
Last Post: MrDiagnostics
  Mhouse Swing gate rmgsecurity Sri Lanka 0 7,017 12-11-2016, 03:00 AM
Last Post: rmgsecurity Sri Lanka
  BFT electric gate Er 35 Chantal 0 7,141 28-11-2015, 07:57 PM
Last Post: Chantal
  Hello. Newbie Q re self fitting gate openers palmiye 4 17,607 28-04-2015, 08:51 AM
Last Post: palmiye
