  • 203 Vote(s) - 2.78 Average
Hydraulic Oil
do gate motors use the same hydraulic motor oil? if so what is the grade.
MWJGATES
www.mwjgates.co.uk
info@mwjgates.co.uk
01327301796
Covering:- Northamptonshire, Warwickshire, Leicestershire.
(21-01-2016, 08:14 PM)MWJONES Wrote: do gate motors use the same hydraulic motor oil? if so what is the grade.
Well its usually the gear box that needs oil not motor. Haha. The answer depends on manufacturers specs and climate for the gear box. I usually do fine with 30w
  can/should i top up hydraulic ram oil? Gatenovice 0 5,343 07-07-2018, 05:49 PM
Last Post: Gatenovice
