  • 225 Vote(s) - 3.14 Average
MotorLift ML700 or 850 blows plug fuses
Hi folks
My faithful MotorLift garage door opener keeps blowing the plug fuse at the end of either an opening or closing manouver. It had a 3A and I tried a 5A and it still blew. When I disconnect the drive and open/close the door manually the door opens and closes easily and has no obvious reasons for an extra load on the motor. I would be in your debt if you no the reason or the solution.
I believe the issue would be the motor coming to the end of its life. As you said it only blows a fuse whilst under load. The pressure at the end of the cycle may be whats causing the motor to blow the fuse. This will be down to the motor becoming faulty.
(02-11-2015, 06:59 PM)olliecat82 Wrote: Hi folks
(20-11-2015, 12:03 PM)Sav Wrote: Hi,
Thanks for your reply. I've now put in a complete new unit and all is well. I did notice that the transformer primary bruned out after a new fuse was used. I think it was old and knacked as you suggested. Thanks Graham
  Motorlift ML850 Reverses on close. LED flashes 11 (!) times. DJBenz 2 19,272 19-01-2016, 07:10 PM
Last Post: DJBenz
  Motorlift 5000 with bad memory 71MGB 2 15,127 13-03-2014, 12:25 PM
Last Post: 71MGB
  Chamberlain MotorLift 5000 Garage Door Opener secash 1 19,457 27-01-2011, 05:55 PM
  motorlift ML 859GB sparkymike 1 11,537 29-06-2010, 04:45 PM
  Where to buy Motorlift Garage Door Openers easygates 0 10,817 13-01-2010, 12:04 PM
  chanberlain motorlift 5000 1 14,139 20-10-2009, 11:01 AM
Last Post: malito100
  MotorLift Garage Door Openers 1 13,958 28-08-2009, 04:02 PM
  ML700-GB - Rail support bracket peterworks 0 11,541 09-01-2009, 03:44 PM
Sad ML700 Skysurfer 2 14,556 06-11-2008, 09:37 PM
Last Post: Skysurfer
