  • 202 Vote(s) - 2.6 Average
Door closes then opens again
This is an intermittent fault - when I close the door, sometimes as I am driving away I can see it has started opening again. I have checked that the photosensors sensors are clear when the door is open and closed. Anyone have any ideas what can cause this? It is a Motorlift 850.
Hello
There are a few possible causes,
1, have you checked when the door is released the door is free to move up and down?
2, i would try taking the cover of the motor and seeing if the main white cog is not worn.
3, it could possibly be a logic board fault, but first i would rule out the first two.
(17-05-2015, 09:07 PM)finescan Wrote: This is an intermittent fault - when I close the door, sometimes as I am driving away I can see it has started opening again. I have checked that the photosensors sensors are clear when the door is open and closed. Anyone have any ideas what can cause this? It is a Motorlift 850.
  remote will open but not close garage door Sharon OWest 4 21,773 01-08-2013, 10:38 AM
Last Post: DJBenz
  Chamberlain MotorLift 5000 Garage Door Opener secash 1 19,433 27-01-2011, 05:55 PM
  Where to buy Motorlift Garage Door Openers easygates 0 10,803 13-01-2010, 12:04 PM
  MotorLift Garage Door Openers 1 13,944 28-08-2009, 04:02 PM
