  • 196 Vote(s) - 2.81 Average
ASO plug and sense installation help
Does anyone have any tricks on fitting rubber safe edge to backing plate. I know soapy water helps. I recently used 45mm edge and had real difficulty in fitting. 65mm is easier to fit but some tips would be good.
Hello
They say soapy water does help, but i always used liquid on it, as it made the edge alot more slippery, also make sure the edges are not cold when your fitting them as it makes it more difficult, try keep them in a warm environment until there ready to fit.
(22-11-2014, 10:12 PM)automatedgates Wrote: Does anyone have any tricks on fitting rubber safe edge to backing plate. I know soapy water helps. I recently used 45mm edge and had real difficulty in fitting. 65mm is easier to fit but some tips would be good.
  New-build installation planned. Terrified I get it wrong! Ian Evans 1 3,967 01-08-2022, 11:53 AM
Last Post: Mr L
  Gate Installation help GrimEire 3 17,658 05-11-2017, 08:51 AM
  Installation corky3377 5 19,319 23-08-2017, 11:09 AM
Last Post: Sheffield1
  Calypso V2 Self Installation leedoncaster 2 12,120 23-01-2017, 12:34 PM
  Add GSM Switch to existing installation? craigside 0 5,503 02-03-2016, 09:25 PM
Last Post: craigside
  Proteco installation in Torquay, Devon James 2 11,984 06-09-2014, 08:59 PM
Last Post: James
