  • 296 Vote(s) - 2.94 Average
CAME Frog and Daitem 902
I'm installing a CAME Frog AE24 system with a Daitem 902 entry phone. No problem with power or connecting the "open" command wires. But I'd like to have the Daitem handsets show when the gates are open - and i don't want to fit a position switch.
So, I see that the Came controller (ZLJ24) will turn on a 24V bulb connected between pins 5 and 10 when the gates are open. So I could connect this to the coil of a 24V relay and use that to mimic a position switch
Anyone see a problem with this?
Is there a better way?
Thanks in advance
James
Seems like the best way to do it. I have used a door contact in the past but this seems like a better way. So I thank you for the idea for the future.
Steve
  CAME Frog AE-p24 kit Push Button Stuartl 2 1,481 20-10-2023, 08:57 PM
Last Post: Stuartl
  Frog A24E motor stopping SW1806 7 5,848 24-03-2023, 02:58 PM
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 7,634 23-02-2023, 01:09 PM
  Came FROG A noisy fezster 1 3,616 30-09-2022, 03:16 PM
  Came FROG - one leaf occasionally does not open fezster 3 7,484 03-08-2021, 10:07 AM
  Came ZM3E and Frog Motors both opening on M1 not seperately giuseppem 1 15,806 11-04-2018, 07:25 AM
  Frog - ZA3: gates won't open BarryD 0 10,180 15-06-2016, 01:34 PM
Last Post: BarryD
  Frog p 230v or 24v ? Emilyjudy 5 32,723 08-03-2014, 01:32 AM
Last Post: stephen70
