  • 233 Vote(s) - 2.64 Average
Roger Receiver programming
On my receiver circuit I see component marked Roger R70/2AC.
I cannot easily identify the programming buttons.
There is a small board at right angles to the main circuit but because of bushes it is difficult to see if the buttons are located on that board.
What size are they likely to be?
Best regards
hi there! On Roger Receiver there are two buttons size about 15X15 mm above LED.
There are several models of Roger receiver so you must know the right procedure for programing.
Unfortunately , I don't remember the procedure for this model... hope this will help you..
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 4,439 28-11-2019, 12:11 AM
Last Post: dawoodejaz@hotmail.com
  Help programming SUN 433 4CH remote jedimatafez 2 8,185 24-02-2019, 08:04 AM
Last Post: jedimatafez
  Programming remote Luke 1 8,161 16-05-2018, 07:38 PM
  Daspi Programming trini_tech 1 10,980 25-06-2015, 09:13 AM
Last Post: thm
  Tousek st 50 programming alban gates 1 10,028 20-10-2011, 11:22 AM
