  • 272 Vote(s) - 2.81 Average
Gate opening all on it's own
Why would my electroc gate all of a sudden open all on it's own? No one is using it's remote controll to activate it! Will do 2 to 3 times all at once, then maybe just once a day, & days not doing it, then do it again? This has just started. Gate has been used probably 10 years, with no problems. Was here when i bought home. Lots of traffic goes by daily. Can open at any time, day, or night! Thank you. Nan
Please email answer. Nancysue39@sbcglobal.net
Could well be a problem with the control board. Especially if it is 10 years old and hasnt been regulary serviced. What is the make and model of the gate openers? Try opening the control board and checking for signs of water, also clean out any spider webs and dirt and make sure there are no slugs on the board. If the gate is opening on its own then there must be something triggering the start circuit on the board, so you could well have a damaged board due to water or spiders, slugs,etc. You should think about getting the gates serviced as they should have a service every year, if you are in our area (midlands) we can do this for you.
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 15,768 22-02-2021, 08:48 PM
Last Post: russ
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 8,529 14-04-2020, 01:45 PM
  Loose gate stop but what wrench to use? bomitie 2 10,242 02-04-2020, 12:06 PM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 30,754 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Sun affecting gate opener ForestRon 0 6,712 02-06-2019, 07:35 PM
Last Post: ForestRon
  Liftmaster sliding gate Kar1e 1 17,274 08-08-2017, 11:23 AM
  5580-GB - reverses after opening ... adambc 1 8,441 27-05-2017, 08:44 PM
  Operating maglocks independent of gate operator onandog 0 6,205 05-12-2015, 05:05 AM
Last Post: onandog
  Opening delay on SCS300 (CB124 board) willows79 0 8,684 02-12-2015, 09:45 PM
Last Post: willows79
  LA400 gate openers 24v Tussun 1 11,331 03-01-2014, 12:10 PM
