  • 366 Vote(s) - 2.72 Average
CAME Ati A3000A - Will not open
One leaf of my gates has just developed a fault & will not open.
If I use the key and open it manually I can get it to close automatically (if I turn the key to get it to engage) so it doesn't look like anything major is wrong.
Can anyone shed any light on what my problem might be ?
TIA.
Is this a double gate (two leaf) system?
Is the motor really stiff to move on release?
If the motor is closing and not opeing and the system is wired correctly then i would say that the motor is not getting a opening supply from the panel.
Could be panel/ cable or motor itself is faulty?
Need some more details
Thanks for your reply.
This is a double gate - the other leaf continues to function correctly. When the malfunctioning motor is released the gate moves pretty freely and will then close electrically if the motor is re-engaged.
Thanks again.
  My Came ZM3E gates won’t open golfnut75 1 5,034 12-08-2022, 08:40 AM
  Came FROG - one leaf occasionally does not open fezster 3 7,485 03-08-2021, 10:07 AM
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 16,462 02-05-2018, 06:18 PM
  Frog - ZA3: gates won't open BarryD 0 10,183 15-06-2016, 01:34 PM
Last Post: BarryD
  CAME double gates - one side closes but will not open crliving 1 17,208 02-08-2013, 09:39 AM
Last Post: Blakey111
