  • 296 Vote(s) - 2.65 Average
ML850 Remotes don't work
Both remotes stopped working shortly after I changed the batteries. Even completing the reprogramming procedure doesn't work. The manual button inside the garage still works. What could cause this and how do I fix it? The opener is a 2004 model.
You either have the batteries in the remote wrong or your have a high level of radio interference in the local area blocking your signal , or the main radio reciever board has blown and need replacing. Repleacement boards can be found on our web pages :
http://easygates.co.uk/product_info.asp?ProductID=337
  Motor lift ml850 protector system rondickinson@btinternet.com 1 9,808 15-04-2019, 09:34 AM
  ML850 no longer operates rivergo1d 1 18,323 12-04-2018, 04:52 PM
Last Post: Tim
  Motorlift ML850 Reverses on close. LED flashes 11 (!) times. DJBenz 2 19,281 19-01-2016, 07:10 PM
Last Post: DJBenz
  84335eml remotes not working Mark65 3 16,030 22-10-2012, 08:26 AM
Last Post: macallan
  ML850. Setting the Limits Brillopad 2 21,467 03-11-2009, 02:49 PM
Last Post: Doorman
