  • 520 Vote(s) - 3.04 Average
Electric gate will not close
Hope someone can help.
My swing gates are set to close automatically after driving through them, however recently rather than the gate trying to close it has tried to reopen again i.e it repeats the opening (or it would were it not already open). It is a hydraulic system made by SEA
I have checked the obstruction sensor in case anything was causing this to engage but that is not the problem.
The indicator lights on the motherboard change sequence from the opening to the closing part of the cycle but the gate is still trying to move to open rather than close.
Any thoughts?
It sounds like you have a sticking relay. try tapping the relays on the board with the non metal end of your screwdriver. Should solve the problem temporarily but will need a new control board in the end.
Hope this helps
WinkHi, I would check out the safety sensors 1st.
Hope this helps
gallows Wrote:Hope someone can help.
Any thoughts?
Thanks for help.... a quick tap on the relays got the gate to close, it then stayed in closing mode and wouldn't open. Further taps get it to move from one mode to the other but it won't switch on its own.
T
Realise this last post was a long time ago, but I have a similar problem. Genius gates, two pairs. One pair working fine, the other sometimes closes after a very long delay, sometimes normally. Is this anything to do with the circuit board in the sensor? No loose wires or anything, but the sensor light is invisible during the time it refuses to close.
The board has identity 30/06 Ftc 911 Rx if that means anything to anyone!
Any advice most welcome.
Thanks.
  Came Frog one side wont close PmIrl 1 128 13-05-2024, 02:40 PM
  Gate mobile phone ‘relay’ jam_rs 1 128 13-05-2024, 02:37 PM
  Nice MC824H gate stuck open Markp80 1 145 13-05-2024, 02:32 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 28 17,720 10-05-2024, 08:27 PM
Last Post: Nemen3242
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 1,892 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Holding the Gate Open mgb 1 4,055 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,313 03-07-2023, 08:54 AM
  BFT gate and Hikvision wiring help Gowrie 0 3,871 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,740 25-05-2023, 03:55 PM
Last Post: Kaala1
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,570 04-05-2023, 04:02 PM
