  • 306 Vote(s) - 2.67 Average
lyn300 control panel
i brought a lyn300 24v double gate kit 2 years ago from easygates and have had loads of problems with the remote controls not working and the only way these can be made to work again is by just turning of the mains supply for a few seconds and turning back on again bearing in mind the batteries are still connected , the remotes work for a short time and then stop working again then its back to resetting system again via turning of the mains supply.
i have already replaced the reciever board and reprogrammed system / fobs
which again works for short period then fails again
any ideas before i look into replacing the control board to see if this resolves the problem
Any clues on cost of replacement cb24
It Is sounding like radio interference in the local area blocking the signals. You need to use a radio scanner and check what else is transmitting on 433.92 mhz to rule out the radio interference.
  Difference: SCS300, LYN300, and LYN400? DevsAd 3 4,055 02-03-2023, 03:12 PM
  Lyn300 lubrication Capricious 5 10,785 08-06-2021, 12:37 PM
Last Post: Capricious
  Control Unit Not Working mtuk100 0 39,167 10-10-2019, 03:14 PM
Last Post: mtuk100
  Which original remote control is suitable for board CB124 Evan 3 9,698 20-06-2019, 04:26 PM
Last Post: Devs
Rolleyes Remote Control Steve 7 32,518 28-04-2016, 08:04 PM
Last Post: Golfmadnut
  LYN300/400 thermiclance 0 7,421 29-10-2012, 08:58 AM
Last Post: thermiclance
  LYN300 Diagnostic light flashing 6 times jeff 3 16,201 02-12-2011, 12:24 PM
  CB11 control box Intercom release button not working Moreteyne 0 8,974 14-09-2011, 03:14 PM
Last Post: Moreteyne
  LYN300 Doesn't Like The Cold! station House 2 19,971 20-04-2010, 08:40 AM
Last Post: station House
  Wiring Photocells on the CB11 control board Sparky 2 21,960 28-06-2009, 10:19 PM
Last Post: Sparky
