  • 289 Vote(s) - 2.7 Average
Problem Setting Limits on CB24 (SCS300-24)
Can anyone help.
I cannot move to the next stage when setting the limits.
CB 24 circuit board.
I have set the open limit and then the close limit and saved it but the light just switches between the two limits and will not go out.
I have tried both sequences open 1, open 2, close 1, close 2 as per the manual and open 1, open 2, close 2, close 1, as per the tech support advise but I cannot move to the next stage to operate both gates with the remote or push button to set the power.
thanks
Andy.
I'm having the exact same problem. Has anyone a solution please?
DQuinn
DQuinn Wrote:I'm having the exact same problem. Has anyone a solution please?
DQuinn
This results because the arm is not moving for at least 60% of it travel.
You need to use at least 60% of the motors travel so that they can recognise the limits
Thanks, Problem solved.
  Difference: SCS300, LYN300, and LYN400? DevsAd 3 4,810 02-03-2023, 03:12 PM
  odd liftmaster scs300-24 scopie88 3 14,023 13-04-2022, 10:20 AM
  Problem with delay time CB11 milan 2 11,654 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 31,760 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
Exclamation lift master SCS300 - photocells Willow 1 11,223 14-07-2016, 09:16 PM
Last Post: Willow
Exclamation lift master SCS300 - photocells Willow 0 8,366 13-07-2016, 11:19 AM
Last Post: Willow
  Opening delay on SCS300 (CB124 board) willows79 0 8,975 02-12-2015, 09:45 PM
Last Post: willows79
  CB24 delay to close random fault stuartdsutton 0 8,662 23-09-2015, 11:38 AM
Last Post: stuartdsutton
  CB22 problem??? Bakota 0 9,466 16-11-2014, 02:25 PM
Last Post: Bakota
  Remote problem Nickhh 1 10,326 30-09-2014, 04:48 PM
