  • 8 Vote(s) - 2.5 Average
Altair-P gates now move in opposite direction with any change to wiring
I have a pair of gates controlled by a BFT Altair-P
They have worked for years giving little trouble. The switches on the remotes sometimes "bounce" giving a start then stop, but otherwise reliable.
Today I had trouble closing the gates.
The remote control is sometime unreliable so I used the manual over ride to try to close the gates. There also may have been a weed growing in the path of the photocell causing a nusiance trigger of the stop an reverse action.
After several attempts at closing the gate I ended up with 1 gate closed and the other gate open.
I mechanically disengaged the open gate to stop any risk of them clashing.
Now using the manual control I can reliably trigger the gates to move, but each time one opens and the other closes or vice versa.
I have put a new battery in my remote and again this now reliably triggers the gates, but one opens and one closes.
I have tried switching the power off and on.
I have tried putting into single gate mode, moving one gate so they are in step and then re-enabling normal (2 gate) mode.
I reloaded the default parameters.
I don't know of any other kind of reset to try. Suggestions?
It would appear I could make this work by swapping one of the motor's wiring,  but how can this become necessary?
Any ideas what has happened and how to fix?
Thank you
William.
Altair-P gates now move in opposite direction with any change to wiring - by william.helsby - 14-05-2020, 11:57 PM
  Two BFT pairs of electric gates (one remote) Harry44 0 5 44 minutes ago
Last Post: Harry44
  smart relay BFT ALTAIR halt23 1 781 13-11-2023, 11:45 AM
  smart relay BFT ALTAIR halt23 1 602 13-11-2023, 11:45 AM
  Gates not fully closing stefen1978@hotmail.co.uk 2 2,952 10-10-2022, 10:07 AM
  Best BFT for closed aluminium gates rafp 1 3,105 13-04-2022, 11:38 AM
  BFT controlled gates open but don't close MikeJep 5 20,177 04-01-2022, 09:58 AM
  Sub BT oil change wbryce 4 9,553 28-01-2021, 12:54 PM
Last Post: wbryce
  Gates not closing (BFT Thalia btl2 and Bft Desme) Joel23M 2 7,938 17-01-2021, 01:25 PM
Last Post: Joel23M
  bft 2b kit wiring mcw1965 2 16,600 04-01-2021, 02:26 AM
Last Post: Bobby2
  Wiring Compacta photocells to Rigel 5 rjmoore 0 11,165 11-05-2020, 06:51 PM
Last Post: rjmoore
