  • 232 Vote(s) - 2.84 Average
Gate not going quite home
Toona 4024 Arm
MC824H Control
CISA Electric Lock
Above kit all set up and working on a 5 bar gate. Trouble is that it doesn't quite slot home into the lock. Literally stops millimetres from the end.
Originally I increased the force to 7 (of 8) and that worked, but noticed a week or so later wasn't going home again.
Spoken to tech help and suggested I resist with my hand when in learning mode and that worked yesterday.
Today, again it is not quite going home. Almost like it has relearnt.
Any ideas please?
Hello
Have you got any type of deceleration set on that system?
if you have this will decrease the speed as it comes to a stop,
or
your geometry might not quite be right, is the nose of the arm pointing towards the gate or is it quite level with the gate?
Sav
(03-12-2013, 04:52 PM)worsy Wrote: Hi
Toona 4024 Arm
MC824H Control
CISA Electric Lock
Any ideas please?
Sav you are a star by just replying. I went out to check the geometry and noticed that one of the bolts through the gate hinge was fouling the arm. Hacksawed the thread off by 2-3 mm and it is perfect.
It was literally touching so I expect that the brackets when done up have settled and moved ever so slightly which caused the issue.
Smile
  Gate stuck after opening. rixman 4 1,094 11-04-2024, 08:10 AM
  Replace receiver nice gate Mebeaker 2 6,624 29-03-2021, 03:42 PM
Last Post: Mebeaker
  wifi gate opener xjust 0 3,468 13-02-2021, 10:42 PM
Last Post: xjust
  Wifi Gate Opener - IT4WIFI problems Mehullakhani 0 6,121 12-08-2020, 11:10 AM
Last Post: Mehullakhani
  Aria gate openers and GSM controller Jamie 2 6,786 25-04-2020, 06:19 PM
Last Post: Jamie
  Nice TOO 3000 Gate opener not closing Sully 1 8,426 17-03-2020, 11:34 AM
  NICE 1500A Gate motor and new intercom - fuse blown Phantome46 0 6,905 19-01-2020, 03:37 PM
Last Post: Phantome46
  NIce Aria 400 unable to program gate open/close Telboy 2 11,447 13-01-2020, 03:33 PM
Last Post: Telboy
  Gate system on our housing complex - Q's RAF96 1 12,584 28-04-2016, 06:15 PM
Last Post: Russ Dalley
  Nice Mindy - One gate doesn't open Danseri 1 12,752 19-01-2016, 11:00 AM
